Avinusa 9" Android head unit
After a bit of reading up, I decided to go with Avinusa's Android unit. I purchased the head unit, the MOST fiber optic amp interface (our GL has the Harman Kardon system), the factory Bluetooth mic adapter, factory back up cam adapter, and factory gps adapter (which I discovered during the install was not needed because the factory gps plug is compatible with the Android head unit).
Install was pretty straight forward. There's a number of YoutYou videos I followed to do the install as far as removing the AC control panel. The toughest part was getting the AC panel off as I was scared to break the trims. Once everything was out, all I had to do was unplug the harnesses and fakra plugs (gps, Bluetooth mic, and back up cam) from the factory unit. The unit harness had the fiber optic plug which I had to remove and plug into the MOST fiber optic amp interface box. Most of the harness from Avinusa come prewired and all I had to wire was the MOST box into the harness (color coordinated so you pretty much just follow the colors; yellow, red, and black for ground). It also comes with two rca plugs that plug into the unit's front right/front left rca input. I ran the USB plug extensions to where the iPod adapter socket was in the glovebox, makes it a clean install and the plugs come out the hole where the iPod adapter socket used to be .
Once everything was plugged in I tested the unit and everything checked out, except the FM radio had no reception. I contacted Avinusa and was told that the Android unit has blue wires labelled as "amp con" and "ant" and these two had to be connected to activate the factory antenna. The prewired harness had "amp con" to "amp con" wired together instead of "amp con" to "ant" so all i did was swap it. There is also a white/purple fakra plug that Avinusa told me to plug into the back of the Android unit, which I at first fixed the issue, but when I push the Android unit back into it's slot to wrap everything up, it starts to lose radio reception again. I decided to just leave it be given I will be using WiFi/usb to play music anyway.
A little kink ran into a few days ago, I got in the car and there was no audio. This was two days after the install. I checked the fuses and everything we're good. I decided to take the unit out and check the wiring and connections, and everything was good as well. I then decided to unplug everything and plug the factory unit back in, voila the sound was back. I contacted Avinusa about the issue, but they haven't replied yet. I go back to the car this morning to put the factory unit back in while I wait to get the issue resolved, but I decided to give it one more try so I turn the car on, and everything works! The sound was back and everything was back to normal. I'm not sure what happened but I will be keeping an eye if the issue happens again. I really am happy with the unit and hoping I don't run into this issue again.
I downloaded Spotify, Waze, and a few other handy apps. The Bluetooth function syncs the phone contacts. I use my smart phone's mobile hotspot to connect to WiFi.
I installed a 'car launcher' app I download on Google Play store to make the set up a little fancier and more "factory like". I hope this helps those who look into changing their factory unit as well as. The install is not too hard if you're somewhat a handy person, and do a lot of reading up before any project.
I cleaned everything up upon finishing the installation. I taped and bundled the wires I wasn't using. I put rubber plugs over the unused rca plugs, and I made sure all the connections were secure.
I'll post some pictures as soon as I figure out how to do that with my phone lol .
It's been almost 2 years now and i still can't get decent FM reception. Avin recommended i buy an antenna with a built in signal amplifier and all would be good. I did, and it wasn't. I finally gave up and just downloaded Pandora, Spotify, and IheartRadio for streaming.
Sometimes, it just doesn't make any sound. The lights and the touchscreen works, but no sound. I can even see Pandora's music timer ticking away...just no sound. Fix: 1) pull over 2) turn off engine 3) remove key 4) open driver's door 5) close driver's door 6) restart engine...and miraculously the music starts playing again. It feels like i am Control + Alt+ Delete'ing my car. Crazy. Avin tech support says they have never had any complaints to the similar
One day my bluetooth just stopped working. Would not connect to anything. Took me SEVEN emails over 2 months just to get Avin to respond. They do not answer they phone. They will not call you even if you request (multiple times )After about 8 more back and forth emails with their suggestions that didn't work (which by the way took them almost a week per suggestion) they told me to pull the unit and do a "hard factory reset". Well, it worked. Unfortunately i cracked my dash face plate when pulling the unit.
So here is my summary: Avin looks cool and almost works as described, but is horribly overpriced for what you get. I could see past the price gouging had the support been half way decent.
I would not recommend them or this unit.
Sorry Avin, you failed!
Feel free to message me if you have any questions. I'll try my best to help 👍🏻
my radio reception is horrid, I only have a single connection for my ant. No dbl white fakra. My unit is the new one with the hdmi out put, and dual outputs for the rear monitors. So maybe they just forgot something... overall I like the unit, but am bummed it cant install android auto.
The oddity is now my parking lights stay on when set to auto. Also, I cant get the obd2 dongle to connect via bluetooth. The password is fine. It just will not connect to it. I can see it in the bluetooth screen, but I cant select it. I only have a single white connector for my radio and my radio reception is horrible. I have the 5m cable but haven't routed it yet.
Has anyone thought of using the coin drawer in the dash as a inductive phone charger? My Note 10+ fits right in there.
I am still having a problem dialing from the iPhone. I can't hear the person I'm calling and they can't hear me. If I hit the phone call button on the steering wheel then dial the number from the keypad on the screen - all is well. Something wrong there, but I don't know what.
