Dash Cam
Old Oct 31, 2018 | 07:59 AM
B Marques's Avatar
2010 C300 4Matic, 2011 GL450, 2005 ML500, 2010 GL350 and 2003 SLK230
Dash Cam
Does anyone have a dash cam? Wondering which is a good one to buy that is a clean install. Like the hidden look.
Old Oct 31, 2018 | 12:17 PM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
I have one installed with no visible wires whatsoever.
It is a roav c1 pro from anker. Great company great camera. 2k quality and gps and great app.
Parking monitor and loop recording.
I would recommend their new s1 camera.
It's connected to the 12v power plug in the passenger footwell and rooted through the trim, up the a pillar and along the windshield frame to behind the rear view mirror.
I cannot see the camera whilst driving and often forget that it is there.
Old Oct 31, 2018 | 01:01 PM
B Marques's Avatar
Old Oct 31, 2018 | 01:39 PM
kombifan's Avatar
Originally Posted by B Marques
it's available for $72 with the following code RV4KINJA
The s1 rivals and outperforms the Blackvue 650s/750s which are considered for many to be the standard.
I just installed the s1 in our families audi and the video quality at 60fps is better than the c1 pro. That being said the c1 pro is still phenomenal in the gl. It's a great camera.
The only camera that outperforms the s1 I think is the Blackvue 950s....but then again you are paying a substantial premium.
Old Oct 31, 2018 | 02:06 PM
B Marques's Avatar
thanks I was going to wait for Black Friday but with that coupon code I think it was a great deal. Bought the S1
Old Oct 31, 2018 | 02:42 PM
kombifan's Avatar
Nice!
Old Oct 31, 2018 | 07:28 PM
TX07GL450's Avatar
Mercedes Benz 2007 GL450 , 2012 BMW 528i
When I connected my dashcam to outlet in passenger footwell, it was on all the time, even at night. I wonder how did you guys deal with this problem?
Old Oct 31, 2018 | 07:45 PM
kombifan's Avatar
Mine shuts off with the ignition and goes into parking mode.
Do you have an older gl?
Old Oct 31, 2018 | 11:55 PM
kombifan's Avatar
b marquees,
If you need pictures of how I installed the camera and routed the cable through the cabin and pillar, just let me know.
Cheers!
Old Nov 1, 2018 | 07:39 AM
TX07GL450's Avatar
yes, it is 2007. so that maybe the reason. My solution is to route the wire to central console outlet.
I couldn't find anyway to program passenger outlet to shut off.
Following was my thread earlier last year.
https://mbworld.org/forums/gl-class-...turns-off.html
Old Nov 1, 2018 | 11:29 AM
kombifan's Avatar
Interesting. It must be that they changed the sensitivity or that they changed the cut off time due to complaints.
Inm sure a lot of people must have inadvertently left things plugged in.
Old Nov 1, 2018 | 03:25 PM
B Marques's Avatar
b marquees,
Cheers!
that would be great. Thanks again
Old Nov 1, 2018 | 08:24 PM
kombifan's Avatar
4 Route the cable under the protective stripping along the door frame.
1 Start from the where you plan on putting the camera. That way you have no excess cable dangling. Route it into the rear view mirrow plastic cover and then direct it to the upper windshield.
2 Then route it under the upper part of the wi dshield.
3 Route it to and Make the corner to the seam. You an pull this a pillar part off. You only need to pull a little as you don't have to take it off entirely. Just route the cable under the seam.
5 route all the way down. Open the side access panel with the plastic pry tool. Route the cable into the side opening through the globe box towards the bottom of the globe box. Hope the makes sense
Completed picture
Route the cable under the globe box assembly outer cover. That way it is tucked in under the panel.
Power outlet
Where you start routing it jnto the glove box side opening
kombifan's Avatar
Sorry for the non chronological order. I couldn't get it to work right when uploading.
Old Nov 1, 2018 | 08:32 PM
B Marques's Avatar
no that is perfect thanks so much. I have my truck getting timing chain done right now so plan on tackling it over the weekend.
