Is there a way to turn off front 12v power socket when ignition turns off
A quick search through manual indicated that that front and rear power sockets are supposed to be hot all the times unless a significant drop in battery voltage is detected.
My question is that is there a way to program these power sockets to turn off once ignition is turned off. My 02 Town and Country has a setting in fuse box where switching the fuse to adjacent place make certain socket to stay on/off. Is something such option available in GL450 ?
I have searched but nothing came up regarding how to make it happen. There are some threads where they talk about changing fuse positions in other Mercedes but nothing about GL 450. Following thread talks about ML in previous generations. Not sure if it will be applicable to to GL.
https://mbworld.org/forums/m-class-w...h-off-ign.html
I can't speak for the front outlets, but the power socket in the rear compartment will turn off after 20 minutes - as you say - if there is no load on it.
However, if there is an electrical load on the socket, it will not time out, and remains powered until the main battery voltage drops to a critical point. The ECU will only then cut power to the socket.
YMMV.
One example of CANBus action occurs on my BMW motorcycle. It has a single, single filament bulb serving as both taillight and brakelight ... it depends on the voltage the controller sends it whether it’s bright enough to be a brake light. Two functions in one wire.
I’d assume all German cars for sure ... and who cares about anything else!
https://en.wikipedia.org/wiki/CAN_bus
