How to use a scan tool (OBD-II)
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Hi fellow members.
I bought a iCarsoft MB II scan tool to see whats going on with my two cars (2010 GL 550 and 2010 GLK 350)
I could connect it through the OBD-II port and power it up
Ran the auto scan that lists all the systems
Went into the systems one by one to read DTCs
Now I have lots and lots of DTC codes. Most of them seem to be false, they gave me the impression that at some point during a battery change, those codes were generated and are waiting there to be read.
My logic tells me to reset everything, drive the car for a while and run the tests again to see what real codes I will be left with.
Does this make any sense?
I got the tool and run the diagnostics but not sure what to do next. In theory I know how to use the scan tool but I don't know what I should be doing next and what the tool is useful for (apart from resetting oil lamp etc.)
I wanted to consult you before resetting the codes as it might not be reversible.
This is the GL if you wonder:
https://streamable.com/19t14
2007 GL450
Of course the clearing is not reversible. It's also not significant. All you have done is cleared a readout. It's like picking up a printout from your printer. If you don't throw away the info, it's not gone.
What I mean is, around the 2:15 mark you can clearly see some error codes related to rear windows but they are working fine.
I have some error codes related to rear parking lights etc but they also are working fine.
Sunroof also the same, works perfect.
So I thought they might have been created when my battery was low or being changed and when I have a new one installed, those didn't go away on their own because the mechanic didn't flush my ECU.
Could this be the reason I'm seeing so many DTCs?
Did you watch the video?
2007 GL450
If you're hoping that someone reading these words, or watching your video, will say "Aha! You have crickets nesting in the fuel system!", well, I think you'll be disappointed. You simply have to assemble more pieces to the puzzle. Write down the codes, clear them, and wait for a problem to occur that you have to troubleshoot. Then dig into it. Make sense?
Yes that makes sense.
My real actual question was:
Is it ok to clear the codes and then drive the car and redo the diagnostics.
So that I'll get a much clear view of what's going on.
The thing is I'm not seeking a magic answer to fix everything that's wrong with my vehicle.
I am an enthusiast and said "Why not" to myself and bought the icarsoft thingy. Now I'm trying to understand what's going on and how to use it.
By how to use it, I don't mean: plug it into the obd port, fire it up, push this and that and voila type of thing.
I want my truck to be in tip top shape and my intention is to fix everything that's wrong with it.
What I meant was is it OK to clear the codes on the car via the device, I don't want to erase something important
My real world concerns are only driver side drl, front driver and passenger door keyless unlocking buttons, slow cranking and occasionally not working ac.
The DTC codes are somewhat important to me becase they might be indicating something important that I might not have experienced like the airbags. If they are not functioning as they should, I want to know. The idea was to reset the code and see if it comes up again, this way I'll know my airbags have a problem.
You made it clear that its perfectly ok to clear the DTC codes. I will do it today.
2007 GL450
Good. Reply with your results.
I keep a bluetooth OBD adapter in at all times so I can check codes and other basic engine data whenever I'm curious or bored. Torque Lite plus a smart phone; life is good.
sorry it’s been busy!
It should be perfectly fine to clear the codes as long as you have the pictures to compare before and after if they do come up again.
It is nice to have a record in case they do.
Most of the codes you posted in the video seem to be low voltage codes that can occur from the battery swap as you said you performed. The others like the keyless go and drl light should come back.
The permanently actuated handle will most likely necessitate replacement.
