ECU coding with SDS?
Old Feb 4, 2019 | 07:04 AM
qxron's Avatar
2021 GLS580
Hello all!
Straight to the point, I want to get a backup used ECU from eBay with matching part numbers. I’m aware that the ECU has to be coded with my VIN? How do I do this? If anyone is familiar with this, advice would be thankfully appreciated! Thanks in advance!
Old Feb 4, 2019 | 08:08 AM
machadosl's Avatar
1999 E240, 2007 GL500, 2004 Suburban Z71, 1997 Ford Escort MK7, 1979 VW Beetle
You should find someone that can reprogram the ECU. I have this done in my car and the ECU and ignition switch as the keys had to be sent to the guy that made the reprogramming to make them "talk".
Unfortunately Star Diagnosis can't do that, it is a little more complicated.
Old Feb 5, 2019 | 03:36 AM
qxron's Avatar
2021 GLS580
Do you think the dealer would do this?
Old Feb 5, 2019 | 04:17 AM
machadosl's Avatar
Here in Brazil and as I know also in Germany, they refuse to do that using the ECU from another car, they only accept if you buy a new one with them. They claim that could be the part from a stolen car.
Old Feb 5, 2019 | 06:29 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Check with Eurocharged or OE Tuning. I believe they have the capability to create a duplicate with whatever tune or lack there of you need.
Old Feb 6, 2019 | 12:21 AM
qxron's Avatar
2021 GLS580
Oh I don’t even know why I didn’t think of them. I’ll check with them tomorrow and hopefully either one of them do. Thanks for this!
Old Feb 6, 2019 | 12:22 AM
qxron's Avatar
2021 GLS580
Ehh. That makes sense. Can’t argue with that.
Old Feb 6, 2019 | 05:19 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
It's not that the dealer refuses to program a used control module....... They can't. Once you install an engine module into a car it will lock itself to that VIN key data. Special equipment and software is needed to virginize the module and then install into another vehicle.
Old Feb 6, 2019 | 05:50 PM
qxron's Avatar
2021 GLS580
Ohhhh. Thanks for this advice. Do you think a tuner can do this?
Old Feb 6, 2019 | 07:07 PM
BlownV8's Avatar
Yes, there are some on this board that have a backup ECU so it can be done. It was a conversation on the 212 E63 section for someone trying to hide the tune from the stock ECU. From what I read, there are other locations that store the information so MB can still see if a tune was ever run on the car.
Old Feb 6, 2019 | 07:56 PM
qxron's Avatar
2021 GLS580
Hopefully this can be done on a used ECU and they can virginize it. What do you think?
