Broken seat adjuster switch
Old Mar 4, 2019 | 06:51 PM
EWT's Avatar
EWT
11 ML550, 95 Supra TT, 14 Audi S4
The fore/aft and up/down adjustment switch on my driver's seat stopped working - it was loose and jiggly and apparently no longer connected to anything. It turned out to be a pretty simple and relatively inexpensive repair as GL repairs go. I forgot to take a picture before putting things back together, but you just pry (carefully - it is made of plastic) off the metallic colored surround and the switch assembly in the picture below is fully visible. Replacement just requires removing four torx screws and unplugging an electrical connector. The part is available from Amazon, FCP Euro and probably many other vendors.
