another airmatic issue
Alternatively, (and this may seem obvious) try swapping the driver's side 'new' strut to the passenger side to see if it inflates. If it does, then you may have a leak/loose line on the driver's side. If not, then you likely have a bad strut.
Hope this helps.
What brand? Check fittings and all connections. Lower car slowly instead of letting it drop.
