2012 GL350 DPF/EGR/SCR/ADBLUE/FLAP delete - WIP & Guide
I have few questions.
1) Which KTAG did you guys used? The one with red PCB? It was working right out of the box or some rework was necessary on the PCB?.
2) How's the engine temperature after you deleted EGR? From my research deleting EGR will increase combustion temperature. Did you notice any difference?
3) How's the odor in cabin? It is very bad or it is ok? Are there any cons on the DPF/EGR/SCR delete you noticed?
question, does anyone know if the SCR/DPF have to be removed?
can they stay on at least temporarily?
thanks
Also, I believe with some systems (Green Diesel Engineering for instance) the reprogramming (re-tuning) is done through the OBDII port which should be much easier to do than to access and open the ECU. Am I missing something?
Also for some reason on the tune I got, torque limiter had to be be turned off in the ECU, as it was going in to limp mode. but now its running great
the BuzzKen pipes replace both the DPF and SCR...
I’m right in the middle of removing both of them now.... I’ll take pics as I go. I already have both upper and lower clamps removed.
Any wisdom on access to the to small hardline pipes that go into the DPF filter that goes up the the pressure sensor? I’m at that point right now and the DPF is out...
Trick is to get it jacked up a bit. Be sure to use jack stands! You don’t want that heavy pig falling on top of you.
And this...
That first seal was just loose in there and the other seal at the inlet of the Turbo doesn’t appear right...
As to the OBDII programming, it depends upon the ECU, Not many support this level of programming via the OBDII port. Many you can program by the connection pins on the ECU module itself (which requires puling the ECU), and unfortunately the ECUs in a 2012 GL350 require the ECU case to be cracked open as there is 1 pad on the mainboard inside the ECU you need to connect in order to program. It sounds daunting, but really not that bad.
