Bridgestone Run Flat Tires for GL 350 on-sale at Amazon
Old Aug 26, 2019 | 04:31 PM
ddruker's Avatar
2011 GL 350, P1 Package, HID headlamps, Blind spot assist, Parktronic, Wood steering wheel
$203 shipped.
https://www.amazon.com/gp/product/B01IFDL9XK/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B01IFDL9XK/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Same tires are $260 - $280 at Costco and at Tire Rack
As much as I hate not having a spare tire and needing run-flats on my truck, this is a good deal. I get my tires installed at Costco for $15 each. This will be my third set of these tires, now at about 83k miles. I also use the GL to tow a 30 foot Airstream trailer and have also done some minor offroading with the last set.
Go get 'em...
Old Aug 26, 2019 | 07:05 PM
johny75's Avatar
'08 GL320
thanks for the tip!
BTW , when you tow, do you inflate them based on the vehicle door sticker, or you go higher? I tow a 6500lb trailer. thx
Old Aug 26, 2019 | 07:49 PM
ddruker's Avatar
Normally I run 34 psi cold all around. When towing the airstream i increase pressire to 38 psi cold in the rears... Towing on the freeway on a very hot day I can see the rears heat up to as high as 46 to 48, according to the tpms.
Old Aug 27, 2019 | 12:54 AM
johny75's Avatar
'08 GL320
Thx for the info!.., and I did not know you could see the tire temp, is that a stock function?
Old Aug 27, 2019 | 01:08 AM
ddruker's Avatar
I am sorry for being confusing.
The tpms lets you monitor tire pressure. Pressure rises as the tires heat up and the gas inside them expands, whether from friction or the ambient air temperature or the road surface temperature.
So what I was saying was that when towing, my rear tires start out at 38 psi cold, but I have seen the pressure increase to as much as 48 psi, as reported by the tpms, due to heating...
Old Aug 27, 2019 | 02:06 AM
johny75's Avatar
'08 GL320
I see.. got it, thx!
