2007 GL450 airbag light code 9023 passenger seat belt buckle need help
Old Aug 29, 2019 | 03:58 AM
mbamg45's Avatar
2007 GL450
so just bought this 2007 GL450 other then the hard start problem i get the code 9023 witch the scan tool says. The component or the signal line to the component S68/2 (front passenger seat belt buckle and seat belt warning switch) has open circuit or resistance to large. my friend sat in the passenger side and it went out one time and worked no srs light but then now its always on ? would it be just the passenger seat belt buckle on the side of the seat that is just faulty or is it the pad in the seat where you sit the problem? i found a used one at the junk yard they are pulling out for me ? is that you guys think the fix just the buckle or anything else i should look at or get ? let me know thanks for any help
Old Sep 1, 2019 | 03:54 AM
mbamg45's Avatar
2007 GL450
Fixed all done no more srs light, looks like someone spilled there coffer down by the seat and into the buckle. Replaced buckle and all done. Now all that is left is the intermittent no start.
