Continental CrossContact LX25 Tires
Now after reading different posts on this site, it appears tire air pressure is a major reason for premature inside tread wear. What is the best air pressure to run on the front and back tires on my 2012 GL350?
Thanking you! Hopefully these tires will last for a little longer with a vehicle with only 73,000 miles and fourth set including the original set that came with the vehicle.
Recommendations: air up to something between M-B's spec and the max pressure printed on the tire sidewall. Rotate tires at every service.
