Slow cranking when engine is hot
Do you know how the temperature impacts the starter? I assume it still gets the same voltage from the battery? Is it some relay inside the starter that goes bad, or, perhaps some contacts are getting worn and do not engage properly when hot? Just curious...
It's important to get on it, because as the starter worsens, the battery takes the punishment.
My car has only 52,818 miles, but here in Brazil our petrol has very low quality, this made the catalyst got clogged.
