2007 GL450 Hard Start intermittent start need help Plz
This is a tricky problem - I even had a mechanic thinking it had to be some fuel problem - because the starter still works; it just goes slow.
I believe that the reason this makes for hard starting is because (I believe) the ECU won't deliver fuel below a certain rpm. After cranking for a second or so, everything loosens up, the cranking rpm rises, and then a burst of fuel.
The starter still works. It just cranks slow, especially when warm. The only diagnostic that will show the problem is one that looks at the crank rpm. Possibly also the current flow to the starter.
or this one is better ?
or this one ?
witch one would you go with or just rebuild my old one ? should i change the positive cable also as they say that might be a problem also or just start with the starter and go from there? thanks
Read the threads here on how to do it.
