Where is the keyless go module located
Old Apr 18, 2020 | 03:37 PM
Lrry's Avatar
X164
I have a 2010 gl 450 and need to change the keyless go module does anyone know where is at?
Old Apr 21, 2020 | 06:08 AM
Droc Rewop's Avatar
X164
It seems there are two different places where it can be. Pre 1.8.2010 it is in the trunk right side. After 1.8.2010 it has been moved to under the floor covering behind the left rear seat (picture shows behind the front seat but text says rear seat).
Old Apr 21, 2020 | 11:51 AM
Lrry's Avatar
X164
Thanks let me check
Old Apr 21, 2020 | 04:16 PM
DarthVaderpa's Avatar
X166 GL550
What's the VIN #?
Old Apr 21, 2020 | 05:44 PM
Lrry's Avatar
X164
4JGBF7BE1AA561954.
Old Apr 23, 2020 | 01:02 PM
X166 GL550
Old Jul 15, 2021 | 10:32 AM
swede76's Avatar
GL550
I know this is an old thread, but I am trying to locate the keyless go module on my 2015 GL550. I cannot find anything anywhere online on it's location and was hoping someone here would be able to help. Thanks!
Old Jul 15, 2021 | 07:28 PM
Tsumi's Avatar
2006 R500
Wrong section. Your 2015 is X166, not X164.
Old Jun 20, 2022 | 10:53 AM
ahaught's Avatar
2011 Mercedes GL350 Bluetec
I found this forum helpful and wanted to share what I found while changing my keyless go module. I have a 2011 GL350 and my keyless go module is located in the rear compartment under the 3rd row passenger window. I was able to remove a few screws and pull the panel from the rear enough to see inside and get it replaced without removing the panel (which is a pretty big job). I purchased the replacement module from ebay, it was not the same number as the one I removed but it works perfectly!
Old Aug 29, 2022 | 07:19 AM
Prince Somorin's Avatar
2009 GL450
Hello:
What were the symptoms that pointed to a bad Keyless Go module?
I can only open my doors with the remote, never with the key in my pocket. Also the push start does not work.
Thanks.
PS: Any easier stuff to check first? The fuse is good.
Old Aug 29, 2022 | 08:01 AM
ahaught's Avatar
Originally Posted by Prince Somorin
Hello:
Thanks.
Those are the symptoms. It's the Keyless Go module. Pick one up on Ebay.
