Can’t start, won’t start??
Old Jun 16, 2020 | 06:13 PM
Wyatt-e's Avatar
2009 GL 320
Newbie here.....My Gl Bluetec stalled on the freeway. I can’t get it to start. It cranks and moves freely with wrench on it. Cranking over, it doesn’t show any rpm. I’ve replaced the crankshaft sensor. No luck. I’ve checked all fuel related fuses. Replaced the fuel filter, I had just started using Renewable diesel, about 1000 miles use. Before this problem started, i had an issue with the urea tank level resetting after it was filled. I also need a new dpf. Any thoughts is welcome......
Last edited by Wyatt-e; Jun 16, 2020 at 07:12 PM. Reason: Crankshaft sensor, not flywheel sensor
