Beloved 09' GL450 won't start, dual cam sensor low voltage codes
Old Jun 23, 2020 | 05:15 PM
nobleeth's Avatar
2009 GL450
Unhappy SOLVED!!! Beloved 09' GL450 won't start, dual cam sensor low voltage codes
To make a long story short I replaced the valve cover gasket (it was leaking into my cylinder 5 which damaged the coil) and since then my car won't start. It tries to start and sputters a bit and even ran for a few seconds but it's not really running. I have a CEL and it says Cam Position Sensor A bank 2 low current and Cam Position Sensor B bank 2 low current.
I flopped sensors with the left side and the errors remained and didn't follow so I have narrowed it down to either the wiring on the driver's side (which moved it a bit to replace the valve cover) or perhaps the ECM.
So questions:
1 - I visually checked the wiring inside the plastic cover and it looks like it's in good shape with no breaks but when I run a volt test both of the cam sensors read 5v on one side of the plug (center is ground) and ) 0.5V on the other side of the plug BUT the passenger side cam sensor harnesses (which are working fine) are showing 5V on one side of the plug and 12V on the other. Would bad wires cause a voltage drop? Is it supposed to be the same voltage on each cam sensor bank?
2 - Could the bad coil have blown the ECM? The coil had a huge visual crack in it.
3 - Can I buy an ECM from EBay (I see them for around $300 used) or does it need to be programmed to my exact car? The ones on EBay are the same part number (which is printed right on the bottom) so is it plug and play?
Thank you in advance!!
Old Jun 24, 2020 | 10:10 PM
nobleeth's Avatar
2009 GL450
Problem solved. I read another thread and it was a fuse that connects both sides of the sensors!! Woo-hoo!!!
Old Jun 25, 2020 | 09:50 AM
tadiguy's Avatar
2014 GL550; 2010 GL450
Great! I could imagine your sigh of relief that the solution was simple and cheap. Please share the thread and the fuse location so that others can benefit from your lesson learned if this were ever to happen to them.
Old Dec 17, 2020 | 03:26 PM
Cosmoapt's Avatar
2007 GL450
Hello what fuse is it?
Thank you,
