Aerated engine oil question
Hi all - if I had introduced a squirt of air into the engine oil while siphoning off some overfill through the dipstick, should I do a complete oil change? I worry about engine oil aeration. The car is a 2007 GL320 / OM642.940... #askingforafriend
ask others but I’d just let it sit for a bit to let any air settle. A few hours at most id think
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Received 3,943 Likes
2017 GLE350 4MATIC
A squirt of air? How and why did that happen? I don’t see any issue. Oil is not a brim-full fluid in the engine (unlike coolant and brake fluid), in fact oil is in contact with air nearly at all times.
Received 1,069 Likes
E55, GLS450, GL63, GLE350
You will need an MB Star to measure the ratio of air to oil. If out of the norm, you will need a full system flush to remove the air from the crankcase and oil pan. While you are having the MB dealership run the scan, please have them check your blinker fluid since low blinker fluid can wreck havoc on your installer valves. If the installer valves are dead, please have them use the unobtanium ones to ensure longevity. Lastly, make sure they use 30 weight ball bearings since those seem to last the longest.
The following 2 users liked this post by BlownV8:
chassis (07-06-2020),
eric_in_sd (02-13-2023)
lol... you cant turn oil into bubbly. if you know the churning that takes place in the oil pan during normal operation you would not care about some air in the oil...
carry on
carry on
2007 GL450
2007 GL450
Or refer them to an exorcist.
2007 GL450
Overfilling with oil results in a low oil pressure fault. Wild, huh?
