Code P0642
Old Jul 15, 2020 | 01:18 AM
Jamm's Avatar
GL450cdi x164
Code P0642
Have a 2010 GL450CDI
When starting this morning CEL showed up. Started fine and drove for 5 kilometers, ran fine, CEL on all the time. When back home, I connected my code reader, and ECU #1 had codes 1611-000 and 2253-000. Cleared CEL and started engine again, no CEL. Did two heat up cycles and checked DTC again, Code P0642 is pending, no CEL
See pictures with Freeze Frames
Old Jul 15, 2020 | 12:32 PM
Jamm's Avatar
GL450cdi x164
Thumbs up
Originally Posted by Plutoe
So clear it again!
Done
Old Aug 11, 2020 | 01:54 AM
Jamm's Avatar
GL450cdi x164
This issue was caused by a faulty engine oil level sensor.
Old Aug 13, 2020 | 10:05 AM
DennisG01's Avatar
'08 GL 320 CDI
Thanks for posting the result! How did you figure it out?
Old Aug 13, 2020 | 12:21 PM
Jamm's Avatar
GL450cdi x164
By connecting a Chinese Star SD4 diagnostic tool, The SD4 narrowed the issue down to 3 sensors, engine oil level sensor, air filter maintenance sensor, or cat diff press sensor. Followed the "Xentry" trouble shooting, and ended up with the engine oil level sensor.
Old Aug 13, 2020 | 07:07 PM
DennisG01's Avatar
'08 GL 320 CDI
Thank you.
