Losing brake fluid fast
Old Jul 19, 2020 | 03:27 PM
JohnAMG's Avatar
3 Porsche rotation
My 2011 GL550 with 196K miles suddenly losing quite a bit of brake fluid which triggered the parking brake sensor. I checked the master cylinder and it was drained half empty. I noticed there are 2 fluid dripping spots; behind the front left undercarriage panel and middle left undercarriage panel, and I assumed there is a brake fluid line running here from front to back. Have anyone ever had this issue? Possible cause and solution?
John
Middle left area
Behind front left wheel
Old Jul 19, 2020 | 04:06 PM
TX07GL450's Avatar
Mercedes Benz 2007 GL450 , 2012 BMW 528i
you will have to remove the splash shield under the vehicle and trace the source of leak. Might have to use UV dye if it comes to that. Then replace that part of line. They sell replacement kits with compression fittings. I hope it is not master cylinder but it may be.
Old Jul 19, 2020 | 04:21 PM
E55Greasemonkey's Avatar
This place is a joke.
Likely pin holes in the hard brake lines from corrosion. MB sells a repair line along with fittings to splice a new piece in place, however it requires a special tool to flare the ends that most dealerships should have.
