GL 350 Engine Seized. Help Please!
Yes, I got the book(need to find it now), and everything was done with the dealership, never have I ever taken the car anywhere else. But the dealership now refuses to replace saying the engine is out of warranty. Post the engine replacement there were around 20,000 miles that were on the engine.
I would escalate to MBUSA, but it seems none of their emails work anymore...so therefore, I would start with a phone conversation with MBUSA.
Find your book and find your invoice for the engine replacement.
Good Luck! I find it odd that your new engine would blow again in just 20k miles if it were new. Did you do all required maintenance?
I'm the same. Being the vehicle is under warranty; a Mercedes dealership is the only mechanics that have touched the vehicle...aside from 1-set of tires.
Edit: Where are you located? I'd like to steer clear of this dealership if I live in the vicinity.
Not sure why you're saying to stay away from the V8, since the GL420 has a different engine (OM629) while it's the V6 diesel engine (OM642) that seems to have issue's with crankshaft sensor, oli-cooler leaks and twc temp sensor.
I'm reading nothing about seized v8 engines? Or am i mistaken?
Welcome to the bluetec seized engine club where thousands are members. Sell the GL for whatever you can, maybe ask $1000, one of the technicians at the dealership may buy it. You might get a little more on trade. Never, ever, buy another diesel Mercedes. Time to go car shopping. If you want to stick with the brand consider a 2012-2019 GLE 350 (166 chassis) GASOLINE powered. Stay away from the V8, and buy a 2wd unless you really need 4matic.
If you have that same book and can prove date of installation; I don't see how your dealer can refuse to honor the warranty and state it is expired.
#32
#33
Again, please share this dealership so others can avoid it. If they are cutting 2-years off of an engine warranty...what other shenanigans are they pulling? I'd have it towed to your local sprinter dealer for the replacement. Your current dealer would not be replacing the engine for me if it was my vehicle.
#34
Exactly, it's not your issue. You have a 4yr/50,000 warranty. The engine gets replace...plain and simple. Unless you want to trade it in for a new/used Mercedes and they give you over book (A truck with a new engine is worth more than a truck that has 100,000 on it's engine).
#35
Received 1,488 Likes
This place is a joke.
Lots of BAD AND INCORRECT information being spread here. This is very simple:
If the engine was replaced under your CPO warranty, the engine warranty expires when the CPO warranty expires, period. Just like the original 4/50k warranty, it ends at 4/50k, period.
If YOU paid for the replacement engine, it carries a 4/50 warranty. Most other parts that YOU purchase carry a 2/24 warranty. Pretty simple.
https://www.mbusa.com/content/dam/mb...20Warranty.pdf
#36
The document you linked also states the following on the first page...
Engines and long blocks are warranted for 48 months or 50,000 miles (36 months or 36,000 miles for Sprinter), whichever comes first, from date of installation.
#37
Received 1,069 Likes
E55, GLS450, GL63, GLE350
Greasemonkey is correct. MB does not honor after the extended warranty is up regardless of what paperwork says.
Question to Emo Ant, did you have the diesel emissions update? If so, this should be covered under that warranty. If not, you may want to get an attorney and see what they can do. MB already lost a major court battle over this engine.
#38
Defects: Mercedes-Benz USA, LLC (MBUSA) warrants to the original purchaser and each subsequent owner of Genuine Mercedes-Benz Parts, equipment, or factory-approved accessories, except tires, installed on a Mercedes-Benz vehicle which is operated in the U.S.A. under normal use and service, to be free from defects in material and workmanship.
If this is the case under CPO or extended CPO, Mercedes would be the original purchaser and the owner would be the subsequent owner which the warranty transfers to.
If what Greasemonkey is saying is correct, when my brand new crate engine was installed; it would have only had a couple month warranty as my extended CPO was ending.
#39
@E55Greasemonkey - that may be how MB USA currently approaches it; but as written it states 4/50 independent of other warranties in effect. There’s no language or catch all stating that end of CPO warranty effectively terminates any other warranty in effect, unless I am missing something.
It might take a round in court to press the issue, or at least a credible threat of one.
Edit: completely forgot about the arbitration option… While time consuming it is the one due diligence step you should take prior to taking legal action.
#40
Point out the wording and try to get them to change their mind. Let them know, since you have the warranty in writing, it may be very compelling to a judge or arbitrator if you have to pursue. Of course, let them know that will be the last resort and you prefer to stay out of the court system. Your state may have a department that handles consumer affairs or maybe a local TV station has an "on your side" type broadcast that could help them change their mind. In addition, I've found getting state and or federal agencies involved, when something really seems off, gets the process moving quickly. If they still do not respond positively, get this in front of an attorney and, at the least, have them write MB a demand letter.
#41
#42
