Mercedes brake fluid 000989080701
Old Aug 5, 2020 | 02:17 PM
GLguy's Avatar
09 GL450
Hi
Does anyone know if Mercedes brake fluid (part #000989080701) is a low viscosity or not? The label says it's DOT 4 PLUS, but the specs do not mention whether it's ISO 4925 class 6 or class 4. I use low viscosity brake fluid in all my other European cars and I'd like to use it for MB as well if I can instead of buying MB specific fluid.
Thanks,
Sergey
Old Aug 5, 2020 | 03:04 PM
dhurley's Avatar
GL320
Originally Posted by GLguy
Hi
Thanks,
Sergey
Dot 4+ is not specifically low viscosity. My understanding 4+ is a higher boiling point version of 4.
What spec does your vehicle call for in the owners manual? Cross reference in Bevo.
Old Aug 5, 2020 | 11:07 PM
TX07GL450's Avatar
Mercedes Benz 2007 GL450 , 2012 BMW 528i
Hi
Thanks,
Sergey
DOT4 works almost as well. I have been running it for past 3 years. Unless you are racing, DOT 4 will serve the purpose.
Old Aug 6, 2020 | 01:06 AM
GLguy's Avatar
09 GL450
I checked the service manual and it just says that DOT 4 plus has higher boiling points (dry and wet). Does not really mention anything about viscosity. I wont be using my low viscosity fluid then.
Old Aug 6, 2020 | 03:14 PM
lkchris's Avatar
'10 CL550, '12 GL550
Hi
Thanks,
Sergey
if the manufacturer of your preferred fluid has a website, check there for their recommendation for Mercedes.
