2007 GL450 rear window and lights not working.
Old Aug 10, 2020 | 01:27 AM
Shizbenzo's Avatar
2007 Mercedes gl450
Hello everyone, I’ve noticed the other night that my passenger side headlights were not working, ok, so I just replaced it with a new bulb and still not working, so I then noticed that the turn signals were not working as well, and only the turn signals on the outside mirrors were still working, but that wasn’t it! Both rear power windows and a power lock had stopped working as well, the battery is brand new and I’ve checked every fuse in all (4) fuse boxes and All are working well, could it be a (RELAY?) (I’m hoping) if you had this problem pls help me out. Thanks
Old Aug 10, 2020 | 08:57 AM
Max Blast's Avatar
NGL450 w/EORP, S550
If you’ve checked all fuses and relays the next step is to have the car read with a Mb Star / DAS scan tool for current or stored codes that may be related to one of your signal acquisition modules (SAMs).
Old Aug 11, 2020 | 12:45 PM
91stealthes's Avatar
2012 GL350
Did all of this start when the new battery was installed?
Old Aug 13, 2020 | 03:21 AM
Shizbenzo's Avatar
2007 Mercedes gl450
@Mat Blast, thanks, will check.
Old Aug 13, 2020 | 03:31 AM
Shizbenzo's Avatar
2007 Mercedes gl450
The battery was a few days old, this happened afterwards, it seemed they all had blown at the same time, I’m hoping it’s a relay.
Old Aug 13, 2020 | 07:18 PM
2012 GL350
What battery did you put in?
Old Aug 14, 2020 | 08:16 AM
Shizbenzo's Avatar
2007 Mercedes gl450
just a new battery (not the auxiliary battery) everything was working properly until I heard someone yelling, “turn on your lights!) that’s when I’ve noticed.
