idle fuel consumption 2008 gl320 cdi
Old Aug 24, 2020 | 09:54 AM
zeichstein's Avatar
x164
Question idle fuel consumption 2008 gl320 cdi
Has anyone determined the fuel consumption rate of the 320 cdi while at idle. I know it will depend on the load. Full alternator load and no a/c are the actual conditions...
Is there a fuel usage variable I can look up while scanning the car with icarsoft?
Old Aug 24, 2020 | 10:08 AM
sak335's Avatar
2012 GL 350
I'm not aware of one. You can determine how many times the injectors pulse at idle with some pretty simple math based upon the RPM and the fact that there are 6 cylinders.. Then you can make an assumption on how much fuel per pulse without load. That should get you to a number that should be reasonably close.
