Airmatic malfunction - C1507 suspension strut is implausible
Can anybody help with how can I troubleshoot this further?
I blew up both rear air springs couple of weeks ago - just got the new Arnott's installed. Lowered the vehicle to normal level, installed the fuse and started up. I can hear the compressor running but vehicle is not rising up.
Any advise?
Regards, Greg
Same goes for the wiring harness to them.
Your compressor is running to refill the central air reservoir, but if your sensors aren’t telling the valve block to distribute air from the reservoir to the rear bags, the car will stay where it is.
What's with the air compressor possibly putting out not enough pressure to fill up? You heard about this?
the x164 airmatic system works like this:
1. compressor charges the air reservoir.
2. Level sensors tell the valve block to distribute air to the four corners to level the car
3. compressor tops up the air reservoir.
4. Cycle repeats.
The MB spec for a good compressor is that it puts out 16 bar in 40 seconds - which is very generous.
This is testable if you have an MB star or DAS scan tool.
I'll be taking apart the compressor side of wheel tomorrow and troubleshooting from there. Will rig up some fittings to check compressor pressure and manually fill air into bags and his block valve.
I used my Autel tool (I have an MS906 which is a pro-level machine) to individually fill each rear air spring in the test mode. Once I did that, it started operating normally again. If you don't have a tool like this, I'm not sure how you can do it, but there has to be a way to clear that fault, perhaps with a normal scan tool.
Could this be that block valve is stuck closed on all of them?
