Error Mercedes Auxiliary Battery
Old Sep 8, 2020 | 09:09 PM
colorado12's Avatar
Mercedes GL 550
Hello . Do I have to install the original Mercedes Auxiliary Battery - Genuine Mercedes 000000004039, or do I also use aftermarket? How long can I drive with the error code? What does this auxiliary battery control? thank you.
Old Sep 8, 2020 | 10:12 PM
Max Blast's Avatar
NGL450 w/EORP, S550
You can use aftermarket. Costs around $40-50 iirc.
just pull out the main battery and then you’ll have access to the aux batt.
some say that unbolting the passenger front seat makes this much easier - either way, you’ll be wrestling something heavy up and out.
the aux batt maintains keep alive functions and memory settings in various systems, but doesn’t affect lighting or starting. it’s just a backup for when your main batt dies so the car can remember it’s settings when you get a new main batt.
I’ve never seen a code refer directly to it. Usually you have to figure out which battery is dying based on which random under voltage alerts and codes are stored.
i just replaced my aux batt with an aftermarket, bit the original MB I took out was still ok 14 yrs later.
Old Sep 11, 2020 | 07:54 PM
lkchris's Avatar
'10 CL550, '12 GL550
The auxiliary battery ensures you can move the transmission out of park when the main battery is dead.
