Brake replacement question
I think I know the answer, but asking just to be sure before I get in a world of hurt unnecessarily.
Does the x164 have SBC?
MB II has a tips option for deactivating SBC, but did not have anything to say about that on the GL and I haven't found anything online to indicate SBC must be deactivated before taking the brakes apart.
Here is a link with steps/pics for anyone who runs into this thread in the future.
https://www.rmeuropean.com/mercedes-...placement.aspx
I have been shocked by the longevity of ceramic pads.
When you say "shocked", do you mean they last longer than OEM which I believe are metalic, or shorter?
I'm going with Brembo rotors and Akebono pads. I was leaning towards Brembo pads as well, but decided to give Akebono a go based on some past threads.
The ceramic pads, EBC at least, have a good tendency to do the "bedding-in" (layer deposition). I think this contributes to the longevity of both the pads and rotors. If the rotors aren't gray - if they are shiny - you aren't doing it right. Not many people know to do this.
Akebonos were seemingly harder than the Brembos when was doing some light research and I'd rather have a longer lasting pad and not having to replace them too often. Bonus for the Akebonos was lest brake dust as well.
I put cheap Detroit Axle rotors and ceramic pads on my daughter's Jeep; bedded them in while driving around on a Sunday morning, and the rotors are a beautiful smooth gray.
Properly bedded-in pads and rotors are so rare that I roll my window down and compliment the driver when I see them.
Tip: If you mess up rotors, you can resurface them yourself with garnet sandpaper. I haven't tried it, but supposedly you just put a sheet between the pad and rotor and then free spin the rotors with the end of the vehicle jacked up. It needs to be garnet because other compounds (aluminum oxide) deposit grains that join the crystalline structure of the iron, like the cementite that forms from overheating.
This is a great article on the dynamics of pad-rotor interaction: https://www.clublexus.com/forums/mai...disc-myth.html
Seems like my street driving style should work with the Akebonos alright. Most times I tend to brake lightly and early compared to most drivers, plus I downshift to scrub some speed. Brake use is mostly for drivers behind me to get the message that the car is slowing down with downshifts. The vacuum on the 5.5L motor is ginormous and combined with the gearing, I am always impressed with the deceleration just by downshifting. I don't think it will be hard to get used to the new pads' characteristics.
I thought I might have been the only one staring at people's wheels, although in my case it's to admire the brakes they are sporting. I am a sucker for a good looking and solid monoblock brake system that can stop a car in no time flat. Yes, tires and suspension also contribute enormously to the brakes' ability to do that. I used to run a custom setup with Porsche monoblock calipers, bigger rotors, and stainless steel lines on my VW's front axle. The rear was light and didn't need anything more than stock calipers, but I did use matching pads front and rear. Especially important when running the car on the track. I was in love with the brake pedal travel, so minimal with that setup. I think I only used 10-15% of the pedal travel before I would reach the ABS engagement point. Tempted to sort out the GL's brakes too with something from the AMG line, but not high on the list of "mods". I'd rather do something with the Command first, although with the amount of use currently (not very much), I can't justify that expense. But enough about my side bar.
I get that the automatics are more sophisticated and the MB units even more so, plus more coslty when it comes to parts/replacement units. Perhaps it's time to rethink the braking habit.
My second car was a Volvo 242 GT. 4-speed manual (with electric overdrive, which the manual said I didn't need to clutch for but always did anyway). Had a new acquaintance in the car, driving on ordinary city streets. Literally the only guy who ever observed: "Do you always double clutch?"
It was a habit I got into thinking about the poor synchromesh gears, but it has a nice side effect of keeping the engine revs up during the shift, though of course it slows down your shifts.
I was in the front passenger seat of a bus driven in New Zealand. I noticed a big sign above the manual transmission stick: DO NOT DOUBLE CLUTCH. I watched the driver try to downshift into a gear. GRRRT. Tried again. GRRRT. Double clutches, vroom, pops right in.
The drive-by-wire throttle does a good job of backing off the throttle imperceptibly when upshifting (there are six gear changes, but I defy you to observe them with masking tape over the tach), but I'm pretty sure it doesn't do anything when downshifting. I suspect liability prevents the designers from doing anything that opens the throttle without the driver instructing it to do so. You'd have to keep on the throttle when slowing to go into the corner, stabbing the throttle whenever tapping the left paddle. When you feel the lurching as you paddle-downshift, that is the engine inertia change buffered by the the torque converter ... and the transmission internals.
I did my first fluid change the other day on my rebuilt transmission, and there was this fine gray silt in the bottom of the pan. I asked the rebuilders about it, and they said it was mostly junk trapped in the oil cooler from the old tranny. That's all clutch wear from inside the trans. Blech.
Wouldn't it be great to reprogram the drive-by-wire to handle downshifts, from lockup to lockup, with the gear change in between? Flip it into a super sport mode, and it keeps the revs between 5 and 7. One can dream.
If the MB is anything like the VW engine (also drive by wire) which I suspect it is and more, when you're braking and pressing the accelerator at the same time, the accelerator input will be negated. You'd see the tach drop to idle, no matter how much you're pressing the accelerator while you're also on the brake. "Stabbing" the accelerator as you described might help as the accelerator input is not constant and the ECU is probably ignoring them if they're sufficiently short. This confirms your thoughts about the drive by wire not taking any action during downshifts.
If I had my way, I'd have a manual 8 speed in this truck mated to the 5.5L. It's the first Auto transmission I have owned in a looong time. It will replace the VWs. My wife's car is auto as well, no paddles on her steering. I guess I just have to accept defeat so to speak and go along with the auto tranny needs. I am tempted to do the transmission fluids myself now rather than task the dealer, just to see what condition the oil and pan are in. The last time it was replaced was approximately 90000KM ago so it's time.... one day when I am motivated to get splashed by transmission fluid and the weather is enjoyable enough.
How did this thread go from brakes to fluids? HA! I guess brakes have fluid too, so not too farfetched.
Doing the tranny fluid really isn't bad. Maybe you saw my thread on my invention. The rebuilder I got my tranny from advocated changes every 25k mi. I guess that's 40k km (40 Mm?). I lagged on it for fear of what I was getting myself into, and put it off until 40k mi. He said it was a very good transmission, and if you change the fluid regularly it will last a long time. 90k km isn't that long of an interval; that's 55k mi.
I strongly advocate doing it yourself, or at a dealer. I took it to a tranny shop and am not convinced they refilled it correctly, because it was just 10k mi later that it took a dump on the highway. Could easily be coincidence, too. I hadn't been super kind to it, having only changed the fluid - did a flush - at 90k mi.
I also was doing aggressive downshifts. For what it's worth. Not too much, though; only a few times when my brake discs were making the steering wheel shake.
When I was first getting into cars, back in the day, I looked at a picture of a clutch disc and asked my more knowledgeable friend what the springs were for. He smiled and said, "That's so the tires don't go BIRP every time you change gears - and then the cops come after you." True story.
A really good driver (which I'm not) is able to smoothly match the engine rpms at every shift, so as to never apply a burst of torque to the drive wheels.
Because the automatic transmission program is (I think) unwilling to open the throttle without the driver telling it to, the transmission has no choice but to take the speed difference between the transmission and the engine and take it out on the transmission clutch discs and bands, buffered by the the torque converter. Conceivably you could do some tricks like tapping the accelerator while downshifting, but I don't know if those work.
Heck, I can't even get the tranny to preemptively downshift when exiting the corner. I stab the pedal ... and wait ... and wait. "Couch on wheels", am I right?
It's complicated, but worth understanding: The "torque converter" is literally nothing more than a liquid coupling that buffers the difference between the engine output speed and the transmission input speed.
The reason manufacturers were suddenly able to make these complicated transmissions with 7-10 gears is because of drive-by-wire throttle management. If the driver stomps the gas pedal, the computer lets off the gas when the shift happens. This is an automatic version of the driver lifting the gas pedal every time he pushes the clutch down. It would be awesome to have a computer that was willing to goose the gas when you downshift, but I guess liability prevents it.
