Windshield wiper
Old Oct 12, 2020 | 09:42 AM
mglsite's Avatar
GL450
Windshield wiper
My wipers are not working. I checked the fuse and it was good and I can get them to work by working the relay. Checked for codes and found none pertaining to the wipers. What next?
Old Oct 12, 2020 | 01:10 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Do other functions on your wiper stalk work properly? Rear wiper? Dim/bright, blinkers?
Old Oct 12, 2020 | 02:39 PM
mglsite's Avatar
GL450
Fixed, wiggled the wires around on the SAM and slammed the hood and the started to work, it's a miracle.
Old Oct 12, 2020 | 04:46 PM
expl0rer's Avatar
GL550 X164
It would be interesting to find out why they stopped working. I would check the connections to the SAM to see if there might be water intrusion or corrosion. This problem might be a warning sign that other bigger (expensive) problems might surface as well.
It's great that you were able to fix it with $0 in parts/labour, doing some preliminary investigation now might save you $$$ later.
Old Oct 12, 2020 | 06:15 PM
mglsite's Avatar
GL450
I read somewhere that if the hood is up that they will not work, I'm thinking the hood switch may have been off a little. The SAM was dry as a bone.
