Oil filter housing and oil cooler torque specs
i have a 2007 GL450 and I’m replacing the oil filter housing gasket and oil cooler gasket.
i was searching the web for torque specs. There’s different torque specs on different videos.
do you guys know the proper torque specs for this bolts? And also is there a torque specs for the thermostat and tensior pulley as well?
thanks and more power!
Thermostat 25Nm
Oil Filter Housing - 20Nm
Oil Cooler 12Nm
35Nm = 25 ft-lbs
30Nm = 22 ft-lbs
25NM = 18.4 ft-lbs
20Nm = 14.75 ft-lbs
12Nm = 8.9 ft-lbs
thank you so much! This will really help me to make sure it will not leak.
