2011 gl450 struggles to turn over !
Hey everyone having a major issue when starting my 2011 gl450. Car was having issues starting and then the upper idler pulley completely fell apart and shredded the belt. Relaced the upper idler pulley and belt and car started fine for about a day and now having the same issue again! Any suggestions? Thanks again!
grenading your pulley could also be a fluke and you may have a weak battery, starter or a combination of both.
windsor21 (01-05-2021)
What's your resting battery voltage? Let the car sit for at least an hour - then turn the lights on for about 30 seconds, then off, then measure after a few minutes. Check your running voltage while you're at it. Do this with a meter right at the battery and also at the jump post under the hood.
Try starting the engine without the belt. How much better is it that way? Check pulleys for drag.
Not turning over is most likely a Battery or Starter issue. A vehicle does NOT require the belt to turn over.
If the battery and starter are in good condition, you should be able to start the vehicle without the belt in place and drive a short distance before the battery drains (since you are not generating power as the belt is not on). So...
Have you tried jump starting the vehicle? If it starts, then your battery is the likely culprit. If not, then it's likely the starter.
Thank you! I am going to replace the battery as that is the easiest first and hopefully that fixes the issues for now. I am sure the starter needs to be replaced as well since the car had 175K on it. Thank you again
Always test before replacing. Otherwise you're guessing and could be wasting money. On the other hand, if the battery is old, it's a good idea to do it anyway. What brand and how old?
