Air sus comp turns back on after reaching max height
Hey guys, my 2011 GL550 last few months has this strange airmatic issue.
Car sits level for a week no issues, I can leave it at max raised height, also stays there. No leaks.
However if I go to lift it, it will reached raised level. Compressor will shut off, but then will turn back on again within 5 seconds and run until it shuts off due to over temp.
SnapOn solus scanner did not show any air matic faults.
Any ideas?
I don't know the logic of the airmatic controller. Does it go to raised height, shuts off based on system pressure, then looks at heights? Do I need to recalibrate the height sensors?
Any ideas?
A guy I just spoke to had the same thing:
Said one height sensor had a dead spot in it.
With buddies snapon canner I can see voltages of each sensor, and can raise/lower each corner individually. Ill play around with it and see what I can find.
I ended up ordered a Star C5 off a forum member here...well know soon enough exactly whats going on.
Im going to inspect the rear accumulator tanks tonight.
Not yet. Scanner should be in next week. Will see what I can find then. I did a comprehensive leak check with soapy water over the weekend. Nothing to note at each bag and connection, air tanks, valve block, or compressor.
