Need Help
Old Jan 10, 2021 | 10:56 AM
Harinderassie's Avatar
2012 GL350 Bluetec
Need Help
Good morning all, I have a 2012 Mercedes Benz GL350 Bluetec in the front fuse box in the engine bay. I had the 40A compressor fuse keep blowing. The compressor was working but very loud. I made a mistake and pulled the compressor relay the third one from the left side the green one and tried another relay and got some sparks and more error codes. Lesson learned to use all original relays from dealer only. I ordered a new compressor as well.
Now i am getting the following error message that will not clear outlined below:
System: ISM-Shift Module
Code:U010087
Description: Communication with the combustion engine control module is faulty. The message is missing
Status: Stored and current
Code:U010087
Description : Communication with the Transmission control module is faulty. The message is missing
System:: AB-Airbag
Code 9194
Description: NO CAN message is received from the control module "N93 (central Gateway (CGW/ZGW) control module)
System:: AB-Airbag
Code 9196 & 9197
System:: SAM-F-Signal acquistion and actuation module front
Code 903C
Description: Component "F58KH (Terminal 15 relay) is faulty or missing, or the feed wire has open circuit.
Status: Stored
Any help on locations of these items so i can check them would help.
Thank in advance
Old Jun 21, 2021 | 02:42 PM
VioB's Avatar
2012 Mercedes GL350
what was the solution? I made the same mistake and pulled the compressorrelay and tried another relayand got some sparks. the car doesn't start anymore.
Old Jun 22, 2021 | 01:23 AM
General Disturb's Avatar
Gl 320 cdi
Originally Posted by VioB
what was the solution? I made the same mistake and pulled the compress relay and tried another relay and got some sparks. the car doesn't start anymore.
Yeah hey
I did the same thing, had to replace the entire front fuse box in the engine bay. You will have cooked one of the circuits on the internal circuit board, if you cant wait to buy another fuse box, you could try pulling it apart and re soldering the busted circuit lines, and then replace improper relay with proper relay of course, but your chances of success with this method are probably low. Better off replacing the whole box.
Cheers
Old Jun 22, 2021 | 08:21 AM
machadosl's Avatar
1999 E240, 2007 GL500, 2004 Suburban Z71, 1997 Ford Escort MK7, 1979 VW Beetle
Be careful, I also had to replace the ISM after a situation like yours, and as @General Disturb has written, I have soldered the busted circuit box, but as this wasn't the best solution, as sometimes I got different errors, I just replaced the fuse box.
I wish you luck.
