2011 GL350 Bluetec problems HELP
Since the sensor and the filter have been cleaned why the heck is this check engine light still on and the car continues to go into Limp mode??? What else could this be?
Any tips would be so appreciated. I’m out $500 just trying to figure this out already.
I'm fairly new to Mercedes but have over 25 years of BMW's, including an X5 diesel I wish I had kept.
If the Mercedes is like the typical BMW, scanning for codes with a brand specific scanner, resetting them, driving for a few miles to see what comes back is step 1 and will determine the next step.
So with what you posted, what code(s) is still present and triggering the CEL?
You also say they cleaned the filter and replaced the sensors. Did they remove the DPF for cleaning or just inject snake oil in it? What sensors? NOx sensors? If they removed and cleaned the PDF and put in new NOx sensors for $500, that is a steal...
A couple of thoughts based on BMW diesel experience.
1. The filter was cleaned. What method?
2. What is the current ash mass vs. max for that filter after it was cleaned? If ash mass is still above the point that triggers a CEL, then the cleaning did not accomplish the goal.
3. After cleaning or replacing the DPF, does Mercedes require a reset of some kind to tell the car to reset the ash mass / other values? Would have to have access to repair procedures to determine and I'm not familiar enough with this car to tell you but someone else here may know.
4. They forced a regen but are all the conditions met for a self regen? For instance, on the X5, the thermostats soft fail whereby coolant temp does not get high enough to trigger a regen. You then end up chasing DPF related codes and replacing DPF, NOx sensors, EGR at great expense when all you really need is a new thermostat. I'm not saying this is what is happening, but the lesson here is that you need to work with a shop that can get to root cause and not just keep replacing parts until they find the right one.
5. These types of issues are the reasons why many people will do an alphabet delete - meaning they delete all the emissions garbage (SRC, DPF, EGR) that tends to become problematic and expensive. That is only possible if there are no emissions checks where you live for as long as you plan on owning it and your clean diesel just became a dirty one.
Hopefully your friend gave you a good deal. My 2011 GL, albeit with 175k miles, was given to me by a friend. She couldn't take it any more. Dealer would not take it on trade and she was sending it to the crusher. I'm still pealing through the onion of issues and have not reached the limit I gave myself before throwing in the towel and selling it.
