Sudden Braking Issue
Drove car on road trip all weekend, no issue. Drove about 60 miles today, no issue. Stopped at car wash and started having issues. Not sure if related or coincidence... when I pulled in to wash, thought I noticed soft brake pedal but didn't think much of it.
Now when I push on brake pedal it begins to apply brake but then gets soft and goes to floor. Very slowly slows car. Fluid looked okay. Got a yellow triangle with exclamation mark on dash and message saying ESP inoperable. Havent been able to hook scanner up since its at home.
anyone ever experience anything similar??.
Thx
In the solid lines?
wtf
This would be a new one on me. I wonder if it rusted or was damaged.
I don't know of anything unusual about the routing of the solid lines, because I've never heard of this on these trucks. I'd put a lot of effort into confirming exactly where the leak is before tearing too much apart.
In the solid lines?
wtf
OP, make certain you're not confusing brake fluid for leaking power steering fluid. If I had to guess, its possibly the 10 cent O-ring that's leaking but I don't know specifics.
Dont be distracted by irrelevant posts about power steering.
Metal line replacement can be complicated, as it’s not certain replacement lines are available pre bent to required shape. Haven’t researched 164, but for 221 all that’s available is straight pieces to be bent to shape locally. In any event, unless you’re doing this at home, this is flat bedding the vehicle to repair facility. Read manual regarding towing ... which is likely prohibited.
Reached out to different dealers for complete hard line replacement part, neither were helpful. Can not locate online..
Best course of action???
Frankly, a little disappointed and surprised the dealer is throwing up their hands.
I live in a No-rust state do there isn’t a big market or knowledge base outside of the custom car scene, but if you live in the rust belt; brake line repair is (or used to be) big business.
You probably could also live with a repair spliced in. I don't think the brake system has terribly high pressures.
