ABS, ESP, CK engine came on can’t shift
Old May 11, 2021 | 09:55 PM
JohnAMG's Avatar
3 Porsche rotation
My 2011 GL550 with 215K miles dash lite up like Christmas tree today with ABS, ESP, check engine, lane change assist warning signs, and I can’t shift out of PARK. Engine did start but couldn’t shift. Anyone know what is going on? TIA
John
Old May 12, 2021 | 07:48 AM
DarthVaderpa's Avatar
X166 GL550
You might have a bad wheel speed sensor.
Old May 12, 2021 | 08:28 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Yes, one that has totally failed can cause these symptoms. Do yourself a favor and only use the MB OEM sensors.
Old May 12, 2021 | 10:44 PM
mefferso's Avatar
BMW 335d
Mine did the same thing with a wheel speed sensor. And do yourself a favor, replace all of them. My first went out at 116k, 2nd at 117k and 3rd at 120k.
Old May 13, 2021 | 07:47 AM
X166 GL550
I had a similar issue and replace all sensors. It is better be safe than sorry.
Old May 13, 2021 | 08:17 AM
BlownV8's Avatar
The speed sensors are an easy DIY. I echo the others who say go ahead and proactively change all of the wheel speed sensors. MB parts are very consistent and that's not always a good thing. If one fails, they will all most likely fail.
Old May 13, 2021 | 09:17 AM
Max Blast's Avatar
NGL450 w/EORP, S550
And for some reason, they will usually fail in short order after a battery rundown/ low voltage event.
Old May 13, 2021 | 10:23 AM
X166 GL550
I used buymercedespartsnow.com to order the sensors. They made sure that parts were compatible with VIN and gave me a good price.
Old May 14, 2021 | 12:34 PM
Yup497's Avatar
2010 GL550 | 2020 S560
2010 GL550
My wheel speed sensor failed at 110k miles, and I too had the same exact dash lights as OP.
Like others have stated, replace them all.
Old May 15, 2021 | 06:23 AM
JohnAMG's Avatar
3 Porsche rotation
Thank you all for the reply and suggestion. I will order speed sensors and try that first.
John
Old May 19, 2021 | 06:28 PM
JohnAMG's Avatar
3 Porsche rotation
I forgot to mentioned beside the errors listed, I also got TPMS and lane change assist failures which were all in working order before this shenanigan begin. I just received the ABS wheel sensors from Pelican Parts. Is there a DIY video on this site for this job? TIA
John
Old May 19, 2021 | 08:45 PM
expl0rer's Avatar
GL550 X164
John
Easy job,
Charge your battery as well, if you have not. Just in case. I had sensor failure after the battery voltage dropped too low.
