08 gl550 rear end bouncy and low
Old Aug 5, 2021 | 02:33 AM
412jinx's Avatar
08 gl550
I have an 08 gl550 which the rear end is low and extremely bouncy, but the front end is normal height. The malfunction sign is on also. I’ve changed the air bags. If anyone has any suggestions it would be greatly appreciated. Thanks in advance
Old Aug 5, 2021 | 10:26 AM
machadosl's Avatar
1999 E240, 2007 GL500, 2004 Suburban Z71, 1997 Ford Escort MK7, 1979 VW Beetle
It seems you need to replace the rear struts...
Old Aug 5, 2021 | 08:05 PM
Max Blast's Avatar
NGL450 w/EORP, S550
And maybe your compressor, because you’ve driven on blown bags. Hopefully just rear bags or even better, a disconnected level sensor or two.
if you drove on those bags the way they are odds are they’ve torn.
Old Aug 6, 2021 | 08:55 AM
Yup497's Avatar
2010 GL550 | 2020 S560
@Max Blast I've been an avid reader on MBworld since 2017. I've read every thread in reference to the x164. If the GL never went with coil springs instead of air, I'd imagine the threads would significantly less.
@412jinx I'm by no mean downplaying your question at all.
