2008 mercedes-benz gl 320 p9006 fix for a/c short on top
Old Aug 30, 2021 | 07:18 PM
Lamont Clemons's Avatar
I have the 2008 mercedes-benz gl 320 cdi x164
I’m doing the p9006 fix (short in the compressor rewire the diode) I’m doing it from the top but I don’t have the colors violet/blk or blue/green. What color should I connect to?
Old Aug 31, 2021 | 07:15 PM
Jeff D's Avatar
1993 300sd
Wink
Old Aug 31, 2021 | 09:43 PM
Originally Posted by Jeff D
Hi on mine the compressor has one color than the harness went to vio/blk on my can , ck the harness side of the connector by compressor you can see it easy!
I don’t see violet black in harness
Old Aug 31, 2021 | 09:50 PM
Jeff D's Avatar
1993 300sd
look under the car ! before you cut into it , look under the car and look at the compressor, hooking up the wrong wire can be a very big costly mistake who knows what the wires all for! ? only MB WIS knows!
Old Aug 31, 2021 | 10:04 PM
right I know but I can see a red wire only
its tight under there
