P0016 Error Help
This weekend, I finally got around to connect with my Star diagnosis, and went through the diagnosis. It led me down the path of pulling the right cover again and checking the intake camshaft adjuster to see if it had twisted. It's in perfect shape, so that's not the problem.
The star diagnosis now says I need to do balance shaft repair... ugh. I am very skeptical of this - I am both weary to do this job (because of the time involved, and because , well, wouldn't the timing be off in the view windows if that were the case?
Before I start throwing more parts, or god forbid, do the balance shaft, I wonder if there are any ideas, none of which seem really that great in my mind. I have some thoughts I could try before I do that.
1. Is it possible the crankshaft position sensor is bad? Wouldn't that throw more than just P0016 (MBZ 1208) code? I'm trying to wrap my head around this - no trouble starting, it fires right up, runs smoothly, perfect.
2. Is it possibly the oil control valve? Wouldn't I get a P0011? Is there a way to test this?
3. Is it possibly, god forbid the wiring to the intake sensor or the crankshaft position sensor?
4. I already changed the oil after the job - is there a need for another oil change?
5. Is there something else? Is it possibly because it just hasn't been driven enough after the 2 months of repairs? Does it need more road time?
I'm just stumped, and hoping the collective brain power here might have a thought on what to chase.
Thanks for your help!
Not too long ago I came across an article which was chacing after similar problems, but it was not in an MB.
https://www.picoauto.com/library/cas...-warning-light
What made an impression on me were the similarities between your case and the one in the article. My diag skills are way below yours or the author's, I'll be the first to admit that. If it was the chain or related parts, getting to them is no fun and takes a significant amount of work and time. I agree with you that it's better to diagnose correctly before a deep dive into the motor again.
Just came across your thread and was wondering how it all turned out?
I have a 2008 GL550 and quite the similar problem. A p0011 error code came up - I had all camshaft sensors and magnets replaced - error went a way for about a week and then it's suddenly back (but only occasionally). All details here: https://mbworld.org/forums/gl-class-...-bank-1-a.html
Would be awesome to hear how you resolved the issue. After all we basically have the same engine (m273).
Cheers from Canada
Seppone
In my case, I don't believe its the sensors or magnets since all 4 have been replace at once.
So why did you not consider to change the timing chain?
I found kits with the chain and some sprockets for around C$570, like this one: https://partsavatar.ca/ina-timing-chain-kit-zc0094k
Labor comes on top - so not cheap, but also not unaffordable.
The other questions is: What will happen if I just leave it? I mean it probably won't rip...
