Power steering?
Old Oct 18, 2021 | 12:53 AM
Antkass's Avatar
GL 450
Power steering?
Wussup guys. My steering wheel is kind of stiff and when turned all the way to the left or right, it makes a wining sound.. Is this a power steering issue? Like, does the pump need replacing? Or the reservoir perhaps?
Old Oct 18, 2021 | 03:57 PM
machadosl's Avatar
1999 E240, 2007 GL500, 2004 Suburban Z71, 1997 Ford Escort MK7, 1979 VW Beetle
Hi! First try to replace the power steering oil, if the problem persists, it seems that the power steering pump is starting to say good bye.
Old Oct 18, 2021 | 05:38 PM
EWT's Avatar
EWT
11 ML550, 95 Supra TT, 14 Audi S4
Could be low fluid. If not, then the pump is wearing out. It isn't too bad of a DIY repair - just make sure to get the proper fluid and bleed properly after install or it will still make noise.
File Type: pdf
Old Oct 19, 2021 | 08:46 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
Replace the steering reservior before replacing the pump. I had this issue and the cause was a dirty filter/screen inside the reservior that starved the pump causing cavitation. I replaced the reservior and its good as new.
