Help! Rear Diff ratio GL320
But I also saw where the diesels are 3.45 ratio and the gas are 3.70 ratio.
Anyone have the straight scoop???
MB Parts houses and Car-Part.com (Used parts search engine) show al GL and R the same.
Several places on the web show the different final drive ratios
I guess I can lift it and check, but I would also need to check the other model that I don't have access to.
2008 Mercedes-Benz GL Class Specifications (thecarconnection.com)
Go in to the page and pick the 320 vs. the 450
I figured that much, just don't know why the parts places are confused,. other than the fact that MB seems to have decided to use one part number.
It seems the R diff is the same. Do any of the R models use the 3.45 ratio?
Just trying to find a decent used Diff of the right ratio.
Shop called, mechanic was happily surprised that the noise was a wheel bearing and not the diff.
Cut my anticipated bill in 1/2
What is really annoying is I am just starting the build of a shop with a lift, so I will no longer be at the mercy of mechanics.
BUT I need the truck for a few trips and to carry material to the shop before it is ready to work in.
