Rear struts out of alignment!
Old Jan 21, 2022 | 01:19 AM
Mikchek's Avatar
2001 S500 (W220) / 2007 GL450 (X164)
I have a 2007 GL450
I’ve had various issues with my AIRmatic suspension which I’ve FINALLY gotten fixed by changing the compressor AND valve block!
Everything seems to work now but the rear drivers side strut is not aligned flush.
is this a problem?
Old Jan 21, 2022 | 08:28 AM
Max Blast's Avatar
NGL450 w/EORP, S550
Yes, the slot needs to line up with the cutout in the lower arm otherwise the bag will be somewhat bent.
sometimes it fixes itself with a loud *SPROING* or other onomatopoeia
Or you can help it by jacking that wheel up, deflating that bag enough to rotate the slots to line up.
glad to hear it’s now (almost) sorted!
Old Jan 21, 2022 | 08:41 AM
Mikchek's Avatar
well I came out this morning and that wheel was low 😩 so I’m guessing that maybe that bag has a leak 🤬
so close but yet so far
i measured it from last night at 1 am to this morning at 8am
Old Jan 21, 2022 | 03:40 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Yeah, half a monster can worth of sag in 7 hrs is out of spec. (10cm per 24 hr period, which amounts to half a german litercola).
New bag?
Old Jan 21, 2022 | 03:42 PM
Mikchek's Avatar
New bag?
I had Midas spray it down with soapy water and they said they didn’t see anything but I’m guessing it could be a slow leak or even be at the top. I’m going to change it today and pray it’s not the hose
Old Jan 27, 2022 | 02:23 PM
Mikchek's Avatar
Got the Strut changed and all has been working ok so far!
Old Jan 28, 2022 | 05:05 PM
expl0rer's Avatar
GL550 X164
I'm wondering how the strut could misalign. During install? If the valve connecting to the airline points inwards like the original strut, the misalignment shouldn't occur. I have a hard time seeing it happening once the strut is installed and the line connected.
Edit: ignore me. I just noticed that the strut spring was not seated properly. I was looking at the arrow and slot where it should fall into place, thinking that they were out of alignment. Doh!!!!
Old Jan 29, 2022 | 06:59 PM
lkchris's Avatar
'10 CL550, '12 GL550
Just FYI, apology in advance.
Strut is a term to describe a unit that combines spring and shock absorber,
This is what your GL has in front.
in rear, your GL has separate springs and shock absorbers. Your problem was with the spring … which in the case of Mercedes Airmatic is a rubber air bag.
Old Jan 29, 2022 | 08:22 PM
expl0rer's Avatar
GL550 X164
Good catch and correction on the terminology. Edited my post to reflect correct terms.
