Removing steering wheel
Old Mar 1, 2022 | 05:35 AM
wannawagon's Avatar
2006 ML320 CDI (2 of) and 2008 GL320
I am going to change the steering wheel on a 2008 (pre facelift) gl. The old one has bad sun damage.
To save having airbag light issues I was going to disconnect the main battery but just wondering if I have to disconnect the auxiliary battery too.
Am I right in thinking I could disconnect the auxiliary battery by disconnecting the small earth wire connecting to the big earth of main battery?
Old Mar 1, 2022 | 08:19 AM
DennisG01's Avatar
'08 GL 320 CDI
I don't know if you "need" to disconnect the aux (probably not?), but it certainly can't hurt. Besides, it only takes a second or two to reach in and slide off the ground connector on the aux battery. There's no downside to doing this.
Old Mar 1, 2022 | 03:42 PM
wannawagon's Avatar
All good
will do
thanks for confirming that the small ground on the main battery earth is the auxiliary
Old Mar 1, 2022 | 06:08 PM
eric_in_sd's Avatar
2007 GL450
I pulled the steering wheel a bunch of times. Never disconnected the battery first.
Old Mar 1, 2022 | 07:49 PM
wannawagon's Avatar
That is interesting. I thought I had heard of people getting airbag light from that.
wonder if it depends on how long the car has had key out
Old Mar 2, 2022 | 12:17 AM
DennisG01's Avatar
'08 GL 320 CDI
Originally Posted by wannawagon
All good
will do
I think you misunderstood what I wrote... I said to slide off the connector on the AUX battery to disable the AUX battery.
Old Mar 2, 2022 | 12:24 AM
wannawagon's Avatar
No worries. Thanks for clarification
I was trying to avoid removing the main battery (or the seat) but it looks imminent
Old Mar 2, 2022 | 08:51 AM
DennisG01's Avatar
'08 GL 320 CDI
To just disconnect the two batteries, you don't need to remove the main battery or the seat. That's why I said "reach in"
Old Mar 2, 2022 | 08:22 PM
wannawagon's Avatar
Ok. I will give it a try on weekend. Don’t recall there being that much space down there but will let you know how i go. Thanks
Old Mar 2, 2022 | 09:06 PM
DennisG01's Avatar
'08 GL 320 CDI
It'll work - been there done that a number of times. Pinch the female connector with your fingers to slide it off the spade connector.
Old Mar 2, 2022 | 11:54 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Speaking of airbags. These were the years that some x164 had the Takata bags. Read up on why you don’t want one of those. I don’t think there was any rhyme or reason as to which did and which did not, but if this requires an airbag swap I would not substitute a non- Takata airbag for a Takata Face Blaster 2000 to facilitate a steering wheel swap. Iirc Takata were legally obligated to replace all of their defective airbags but had yet as of 2019 to publish a replacement schedule for x164.
https://static.nhtsa.gov/odi/rcl/2016/RCMN-16V081-3087.pdf
Old Mar 3, 2022 | 10:51 AM
eric_in_sd's Avatar
2007 GL450
Dunno. All I know is, if the SRS error came on, it self cleared shortly.
Old Mar 3, 2022 | 03:05 PM
wannawagon's Avatar
that is great news. Only done early BMW stuff before and when it came on it was on till cleared with scanner
