Suspension Rebuild
Old Apr 3, 2022 | 12:44 PM
atraudes's Avatar
2011 E350 Wagon, 2010 GL450
Oh yeah, make sure you torque the axle nut to spec when you reassemble. I only did good n tight and it destroyed the bearing
Old Apr 3, 2022 | 06:41 PM
Max Blast's Avatar
NGL450 w/EORP, S550
And then the bearing goes in one way; and one way only - otherwise no ABS.
Old Apr 4, 2022 | 10:33 AM
not2fast's Avatar
In the market
Well one side is done along with sway bar. I am waiting for bolts for PS Bushings and other strut to complete the other side. Then I can get an alignment.
Clock is running out before getting summer toys out of winter storage.
Old Apr 11, 2022 | 10:08 AM
not2fast's Avatar
In the market
Well I was worried this would happen. When I tried to hammer out my driveshaft I damaged the wheel bearing. I ordered a cheap one from Amazon, but didn't know when it would arrive today so I just went and picked up one from the dealer.
I get home this AM from dealer and Amazon already delivered. Interestingly there is a noticeable difference in weight between the two. It certainly seems like a good idea to stick with MB wheel bearings.
Old Apr 11, 2022 | 11:15 AM
atraudes's Avatar
Aw man, sorry to hear that! What brand did you order? If it's Timken or National I wouldn't sweat it at all.
Old Apr 11, 2022 | 11:16 AM
Max Blast's Avatar
NGL450 w/EORP, S550
Eh, stick with OEM. The bearings are directional and need to be installed one way to allow the proper function of the magnetic reluctor for the ESP and ABS.
Plenty of risk of chinesium not having this function and future aggravation when you’re all buttoned up and your abs is going nuts.
Old Apr 11, 2022 | 11:22 AM
  #32
not2fast's Avatar
In the market
I just bought factory one since dealer had it. O'Reilly had them too. The Amazon ones are WJB which seem to be junk even with so so reviews.
Old Apr 11, 2022 | 11:34 AM
  #33
not2fast's Avatar
In the market
I pulled the hub assembly out and dropped it off somewhere to pull the old one out and put in the new one today so I can get it all back together work.
I hope those guys get it right putting it in. I thought about renting or investing in tools to do it myself, but wife is getting jealous how much time I am spending with Cede. (pronouced Sadie in our home)
Old Apr 14, 2022 | 09:29 AM
  #34
not2fast's Avatar
In the market
I will have it all back together today. The PS bushings were good. (I spent an hour looking for the strut control bolt. It rolled away.)
Overall all of the bushings looked good, but all ball joints certainly were loose-ish but looked fine. New shocks and struts should help.
I still need to replace the rear struts and change the idler pulleys with the FCP Euro kit.
Old Apr 14, 2022 | 09:35 AM
  #35
not2fast's Avatar
In the market
Fall/Spring wheels on the M3. I am wondering if some of my thoughts on the GL550 feeling floaty and loose are from driving my M3.
Old Apr 14, 2022 | 11:19 AM
  #36
Max Blast's Avatar
NGL450 w/EORP, S550
An x164 should handle like a couch on wheels so maybe your butt dyno has been sensitized by the M3.
Old Apr 14, 2022 | 11:20 AM
  #37
atraudes's Avatar
Nice ride! Heck, the GL feels floaty compared to my E350
Old Apr 14, 2022 | 11:40 AM
  #38
not2fast's Avatar
In the market
I am thinking it might be that. I got the GL550 after a Q7 and it certainly didn't drive as car like, but lately I have felt the GL550 has been driving like a pickup. I will be curious if the suspension refresh changes that.
Old Apr 14, 2022 | 09:18 PM
  #39
not2fast's Avatar
In the market
ABS light is on. SOB.
Old Apr 16, 2022 | 10:33 AM
  #40
not2fast's Avatar
In the market
Turns out the new Wheel Bearing I had put in by a shop is bad. Could that get screwed up putting the spindle back in? Maybe over tightening CV axle bolt?
Old Apr 16, 2022 | 11:13 AM
  #41
Max Blast's Avatar
NGL450 w/EORP, S550
It’s either a bearing that isn’t even compatible with your car because it’s cheap Chinesium, or they put it in the wrong way, and messed it up in the process. get OEM.
Old Apr 16, 2022 | 11:56 AM
  #42
not2fast's Avatar
In the market
I am guessing it was installed wrong way since ABS doesn't work either. I drove it around the block and it made all kinds of noise and ABS lights were on.
The bearing was OEM that I picked up at the dealer. I had Amazon cheap one ordered at same time.
It is WJB brand. In the box it weighs 2.4lbs. (comes with install instructions on directly install)
The OEM one weighs 3.4lbs in the box. (no instructions)
Visually they look the same.
Old Apr 16, 2022 | 02:49 PM
  #43
atraudes's Avatar
You’d have a tough time overtorquing it without power tools. Did you follow the torque spec for the bearing? Mine got ruined because I didn’t torque it enough, which was already super tight. Agree that it was probably backwards. Go back and have them do it again at their expense. It’s a pretty stupid thing for a shop to flub
Old Apr 16, 2022 | 07:04 PM
  #44
Max Blast's Avatar
NGL450 w/EORP, S550
my guess is that this wjb doesn’t have the denser metal reluctor that allows the speed sensor to read wheel speed.
Old Apr 19, 2022 | 09:17 AM
  #45
not2fast's Avatar
In the market
Well it is back together and I have put about 20 miles on it.
Nothing was bad or ready to fail, but replacing everything up front and rear shocks did firm up everything nicely. I am thinking I might replace the rear sway bar end links at some point based on how the front ones felt.
Old Apr 19, 2022 | 02:50 PM
  #46
Max Blast's Avatar
NGL450 w/EORP, S550
Did you get the proper ADS shocks?
Old Apr 19, 2022 | 04:18 PM
  #47
not2fast's Avatar
In the market
Yes - Wouldn't I get error messages without them?
Old Apr 19, 2022 | 11:17 PM
  #48
Max Blast's Avatar
NGL450 w/EORP, S550
Yes, and a worse ride as well.
Old Apr 22, 2022 | 10:09 AM
  #49
not2fast's Avatar
In the market
Well I am ditching the chinese rear shocks after a week. When I floor it I am feel excessive weight transfer to rear and they seem to be nosier to boot. I ordered up Bilsteins at Rock Auto. I will put in new rear sway bar end links when inswap in the new struts next week.
I looked at Arnnott, but figure I will just go with the name a trust. I spent enough time trying to get my suspension setup right on track cars so I might be more sensitive then most.
Old Apr 28, 2022 | 11:23 AM
  #50
not2fast's Avatar
In the market
The Bilstein's are worlds better in the back. If I was doing everything all over I probably wouldn't have replaced on bushings and endlinks up front and just went with Bilstein sturts all around.
