Will these 18 inch wheels fit GL550
Old Apr 25, 2022 | 08:18 PM
JesusV's Avatar
2012 GL550, 2016 C300, 2005 Mustang
I'm nearing the time to buy new tires and I'm debating on getting 18 inch wheels and tires. For the same price of a new 21inch tire set, I can get a complete wheel and tire set. The 21's are terrible for tire options, they're expensive and don't last very long in my experience. So I'm looking for more threadlike and bigger sidewall. I found these
https://www.ebay.com/itm/28432027421....c100667.m2042
They have a close offset to the AMG's ET37 stock vs 18's ET35. So will they fit?
Old Apr 25, 2022 | 10:47 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Probably not as they are for the car platforms and not designed to carry GL weight.
these 18s will fit:
https://www.ebay.com/itm/Mercedes-X1...-127632-2357-0
if you want to go big these 19s will also fit.
Old Apr 26, 2022 | 07:24 AM
JesusV's Avatar
these 18s will fit:
Thanks for the response and recommendation! Will look into those wheels instead.
Old Apr 28, 2022 | 07:04 PM
expl0rer's Avatar
GL550 X164
If you can find MB wheels part number 1664012202, 20 inch ET +41, your choice of tires will be better. I find that tire choices in the 19 inch category are not as plentiful as 18 or 20. As you said, choices in 21" are limited.
Adding a link:
https://www.ebay.com/itm/25302222369...4AAOSwyytauKn-
Old Apr 29, 2022 | 08:47 AM
JesusV's Avatar
Adding a link:
Thanks for the link, I ended up finding these replacement tires https://www.tirerack.com/tires/tires...cleSearch=true 285/45/21 tire which will give me a bit more side wall and 50k warranty. Couldn't wait to find wheels, my tires needed change and I do like the 21inch AMG wheels, just not the lack of tire sizes.
Old Apr 30, 2022 | 10:00 PM
expl0rer's Avatar
GL550 X164
Those tires were on my list when I was searching for a replacement set. Good choice. You probably know already, but I'll say it anyway. Your speedometer will display your speed slightly higher than your actual speed.
Old May 1, 2022 | 02:47 PM
JesusV's Avatar
Yeah I hope to get the technician to fix it for me when I bring it for service.
