2008 GL450 Starts then dies.
Old Jul 12, 2022 | 12:42 PM
norcalcasey's Avatar
2006 C55, 2004 ML350
I have been in the market for a new (to me) Mercedes again. Ive had a W163 ML, a W203 C55, and a old 190E.
Locally a 2008 GL450 just popped up on martketplace with 100k for $3000. Pictures look decent, no air suspension sagging which I know can be a problem with these.
The problem the seller states "Starts and dies then have to let sit four hour and then it will start and die." I know on the M112/M113 motos this usually meant a crankshaft sensor issue.
I am well versed with wrenching and have a scan tool.
Any idea what this might be before I go look at it?
Thanks,
Old Jul 12, 2022 | 04:07 PM
Miguk_Saram's Avatar
'07 GL450
The scan tool will tell you plenty. However, without the codes my money is on a bad Fuel Pump.
Old Jul 12, 2022 | 05:29 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
99 out of a 100 times, this is the issue on the 164.
Old Jul 12, 2022 | 08:24 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Thanks,
check for standing water under both seats and in the deep trunk. If wet, it’s a parts car worth half..
