what is this sensor?
Old Jul 20, 2022 | 09:25 PM
CreativeS's Avatar
2012 GL350
Hi,
The serpentine belt broke and an air pressure burst felt and loose a bit power, it broke the sensor too. when race i feel an air is leaking with pressure. with scanner (Torque OBD) it shows "P007D Powertrain". here are few pictures. Kindly help if you the the part number for it and if it can be an easy diy.
Old Jul 20, 2022 | 09:46 PM
wae's Avatar
wae
2012 GL350
Is it maybe A-651-153-00-28 - Air intake temperature sensor?
Old Jul 21, 2022 | 02:02 AM
Max Blast's Avatar
NGL450 w/EORP, S550
On a diesel?
Old Jul 21, 2022 | 05:33 AM
CreativeS's Avatar
2012 GL350
Originally Posted by Max Blast
On a diesel?
yes. 2012 GL350 Diesel
Old Jul 21, 2022 | 02:58 PM
CreativeS's Avatar
2012 GL350
Thank you Wae. I called my dealer parts center and sent these pics, I gave him this part number but he still cant confirm but he sent me this picture. Can anyone check if have same model to confirm if this is the right sensor?
Old Jul 21, 2022 | 03:28 PM
wae's Avatar
wae
2012 GL350
Okay, I'm flipping around in WIS and EPC here and that is identified as B17/8. The wiring diagram appears to indicate that the wires should be BN/BU and GN/WH. The wiring diagram calls it the "Charge air temperature sensor". I am reasonably certain that #110 on the EPC diagram there is the correct sensor. I would go out and look on mine but I just dropped it off for the consent decree work yesterday.
Unfortunately, if there's a way to translate the electrical diagram reference to a part number I am not aware of it... But when I do a search for the part number I put out there earlier, the picture that comes up matches the picture of "B17/8" in WIS.
Old Jul 21, 2022 | 03:33 PM
wae's Avatar
wae
2012 GL350
Oh, and it appears that there is also an o-ring that goes in there. I assume that the new sensor would come with one, but check to make sure.
Also... not to be too much of a worrier here, but where did the sensor go? Hopefully it went out as opposed to FOD-ing your engine... It's probably too late, but you might pop the boost pipe off the intake tube there and look for any evidence or chunks. Best case is that it broke off and shot out. Second best is that the sensor portion is still whole and jammed up in the butterfly valve.
Old Jul 21, 2022 | 03:53 PM
CreativeS's Avatar
2012 GL350
Yes, rockauto part description says Air Intake / Charge Temperature Sensor.
your picture is showing exact placement where the hole is for sensor.
I put my pinky nothing there and removed the intake tube to check no debree. i think when a loud bang noise came it might be that sensor blown away.
thank you for the heads up for o ring, i will double check.
Old Jul 22, 2022 | 11:31 PM
CreativeS's Avatar
2012 GL350
update: got confirmed with local mechanic its the right part. Got it from dealer and installed. All good now...
Thank you Wae, appreciate your help.
