2011 GL550 ESP Inoperative
Any insight is appreciated.
I scanned and reset codes with iCarsoft scanner and these are the codes that come back:
DTC 5035 - No CAN Message Was Received from Control Unit N80 (Steering Column Module). DTC Status stored
DTC 9065 - No CAN Message Was Received from Control Unit ABR (Adapthive Brake) or ESP. DTC Status stored
DTC C126 - No CAN Message Was Received From Control Unit N80 (Steering Column Module) Are not Available on the CAN Bus. DTC Status stored
ESP can be triggered off for a variety of reasons, one of them is a steering angle sensor failing… Who knows what quality part prior owner used.
Other reasons for having this would be failing wheel speed sensors or ESP/ABS ecu errors.
