Tailgate control
GL450
Tailgate control
The tailgate works fine with the key fob. The issue is the switch in the drivers' door. This one does not work. Is there a way to test the switch to determine if it needs replacement.
Thanks.
Thanks.
Well, in the old days I would say just jump the switch. How many wires does the switch have and what color are they? Is there a quick disconnect connector? A paper clip comes to mind....
If the interior switch at the liftgate also works, the driver's door switch are probably not all that expensive and it's a pretty safe bet that's the problem.
2007 GL450
No.
Also, the door switches route through a lil computer in the door. That could be your problem also. Take off the door panel and try bypassing the switch.
My lil door computer failed because I installed a Chinesium master switch panel. Failure is not common but it does happen.
2013 ML350 Bluetec
No.
Eric, are you sure it can't just be popped out? I thought it was just held in place by friction with spring tabs... but still able to be wiggled out?
2007 GL450
However, removing the door panel is pretty easy if you follow the steps. I suggest that removing it is easier than removing the switch without damaging the exterior of the door panel. No harm in trying, though, right?
Ratchet steps... that sounds right. Usually, with this type of thing, you can wiggle it out - sometimes a thin, plastic scraper (maybe a credit card?) can help as you can get under the lip of the "faceplate" and put pressure on the ratchet strap. I've never removed this particular switch but have removed others that way. But, as you said, removing the door panel is pretty straight forward and quick - it's been a couple years since I removed one of mine but I recall it being a no brainer.
