Keyless Go location?
I have a 2012 GL550.
Thx
If you post your VIN, I'll plug it in to my WIS and see what it has to say about Keyless Go.
My vin is: 4JGBF8GE1CA779667
Thx
Thx
Gl550 2010…
Rear right panel…
I think same location for 2012
Gl550 2010…
Rear right panel…
I think same location for 2012[/QUOTE
Thanks for this picture! Is it difficult to remove the cover to access the area? Looks intimidating. Thx
the book method is to remove the interior. It’s a bit fiddly but there is another nondestructive cheat - it’s easy to get them flexed far enough forwards to gain access to these modules. Just work from back to front wrt bolt removal and when you have access, stop. in all actuality, the tricky part is getting the second row seat belts, and their mounts out from behind the interior panels.
otherwise, rip the armrest off. Roll the dice on your hot glue gun repair holding up.
I tackled this job yesterday. It went easier than I imagined.
Take out 3 T30 Torx screws
Partially pull away weather stripping on rear side and also in right rear passenger side
Pull trim piece away from 3 clips in passenger doorway
Then from rear, carefully pull piece away from side towards middle of car until two trim panel retainers on rear of piece pop out.
At this point the piece is loose enough to wedge your hand inside to where the module is located.
Remove two retaining nuts on module, disconnect the 3 wire connectors and remove module.
It’s a little easier to reach in through fuse cover opening to remove the nuts and wires.
Installation is reverse.
The hardest part was fitting my hand behind the trim piece to release the wire connectors. My wrists were pretty scratched up from fiddling around in there. The antenna wire is long enough to move the module into an easier location to remove it so disconnect the other two first.
The dealer wanted $600 for the part and $300 labor to fix the keyless go. I bought the module for $100 on eBay and installed it myself saving $800. Sweet!
Thanks to the members here for helping with information and advice before I started. Hopefully my write up will help someone else.
