ISM Actuation test
Old Jan 27, 2023 | 07:48 PM
EmilyMB's Avatar
gl550
ISM Actuation test
I need your help here guys, please check yours if you can
I tried to run Actuation test ( Actuation of Actuator Motor in Position P R N D ) for my GL550 2010 ISM module ,
and got the message "Drive to workshop without changing gear" popped right up on the dashboard with TCM error code: C103 and 1709,
but car still be able to start.
(car won't start if leave overnight in cold weather with message "Drive to workshop w/o changing gear," unplug/reconnect battery cable to be able starting the car.
I just want to make sure it is ISM failure before replacing it.
TIA
