2007 Gl450 Airmatic problem
2007 Mercedes-Benz GL450
Hi guys,
I have a 2007 GL450 that is experiencing Airmatic issues. It keeps kicking up code 5507 (suspension strut is implausible) after trying to raise the suspension with the airmatic button on the console. It does raise the suspension some (all four height sensors showing change in height), but after a while, it kicks on the airmatic malfunction warning. When trying to lower the suspension, it lowers the suspension some, but continues to show that it is still lowering via the airmatic message, without actually lowering after a short time. After hooking up my scanner and viewing the airmatic pressure sensor (Y36b1), I noticed the readings are extremely sporadic (see attached video). Is this caused by a faulty compressor or possibly the valve block? Hoping it's not the compressor, as I have had to replace this twice already in the past. I also replaced the valve block in the past as well.
Hi guys,
2010 ML550 VIN WDC1641722A564750, 2010 B180
Compressors only die due to being overworked because of a leak. You didn't say if you had replaced any airbags (the usual culprit) at all, but you've been through 3 compressors? The malfunction warning is the compressor overheating. Have you done a soapy water test on all components?
Max Blast (02-12-2023)
2007 GL450
Are you using an AMK branded compressor? Chinesium compressors fail quickly. Varying air pressure at the sensor could result from that.
Your varying air pressure could also be due to a Chinesium valve block, with a garbage pressure sensor and garbage valves.
When it comes to the pump and valve block only get AMK; the good valve blocks all cost in the mid $250 range. I put in a $50 Ebay valve block and it never worked at all.
